Hello folks i have a rather basic question.
Let us say an electronic/ electrical device like a simple light bulb is rated at 120 volts at .25amps current. That would make the power consumption of the bulb 30 watts. will this same light bulb turn on and function normally if i were to give it 30 volts at 1 amps current?
my question in other words is , will an electronic / electrical device do what it is meant to do if you give it the right amount of power even while you are changing the ratios of the voltage and current.
thanks
thanks
