Simple Band-pass Filter - passband voltage drop
Rtier
Joined Mar 12, 2009
First, a quick thanks in advance. I am looking to have my process verified - I used the example numbers from the book to guide myself. I'm doing homework involving band-pass filters and I'm not confident I understand the voltage drop across a pass-band filter. I'm working with RC high pass and low pass filters in series, not sallen-key filters.
The example in the book's section on band-pass filters has a high pass RC filter in series with a low pass RC filter. C-high = 1.5nF, R-high = 1kΩ; R-low = 40kΩ, C-low = 4pF.
Low cut-off frequency = 106.1kHz
High cut-off frequency = 994.72kHz.
The book's analysis at ~500kHz shows a Vo ≈ 0.9Vi.
In my analysis, I assumed Vi = 1V for simplicity, and obtained Vo = 0.874V.
First, I figured out the reactance of both capacitors:
Xc high = (2*pi*500000*1.5*10^(-9))^-1 = 212.2Ω
Xc low = (2*pi*500000*4*10^(-12))^-1 = 79.6kΩ
Next, since the diagram shows a high-pass filter as the first stage, I went through the Av for it first.
Av high = (1+ (Xc/R)^2)^(-0.5)
Av high = (1 + (212.2Ω/1000Ω)^2)^(-0.5) = 0.97822
Then, the low pass filter.
Av low = (1 + (R/Xc)^2)^(-0.5)
Av low = (1 + (40kΩ/79.6kΩ)^2)^(-0.5) = 0.89348
Multiplying these numbers together gives the Av for the entire bandpass filter, Av = 0.874Vin.
Anyone care to comment? Reassurance would be very very nice at this point. Sorry for the MSPaint circuit drawing, I don't have access to MultiSim right now.
Audioguru
Joined Dec 20, 2007
11,248
The filters are so simple and their frequencies are so close together that they affect each other.
The lowpass filter cuts high frequencies but it also cuts the frequency you want.
The highpass filter cuts low frequencies but it also cuts the frequency you want.
Your circuit is too simple to do what you want.
Rtier
Joined Mar 12, 2009
I edited the original post to reflect the proper frequencies. I had mistakenly noted (through poor notation) that the low pass filter cut off frequencies above 106.1kHz and the high pass cut off frequencies below 994.72kHz. It works the other way around.
The Electrician
Joined Oct 9, 2007
2,970
You ask for comment, but I think it would be more fruitful if you asked a question.
Are you questioning the apparent discrepancy between the book's analysis giving an Av of .9, versus your value of .874?
Perhaps they are just rounding the result to one digit.
However, your value of .874 is only correct if there is a unity gain buffer between the stages. That's the implicit assumption you make when you simply multiply the Av of stage 1 times the Av of stage 2.
If the stages are cascaded without a buffer, the overall Av is .87205. You have to analyze the complete cascade of 4 components, all at once.
This value is pretty close to .874, and the impedances of the two stages are scaled in order to prevent the second stage from loading the first stage very much, but there is a small loading effect, which accounts for the correct Av of .87205 compared to your value of .874.
