Simple Automation using pic16f mico.
Discussion in 'General Electronics Chat' started by DHEN, Dec 12, 2009.
  1. DHEN
    Dec 7, 2009
    9
    Does anyone know of a cheap water or air pump? I need to move water from a reservoir up about 2' to another container. Any and all ideas are greatly appreciated!
  2. bluebrakes
    Oct 17, 2009
    245
    7
    what spec? voltage, etc.
  3. DHEN
    Dec 7, 2009
    9
    I would like for it to be battery powered. some where between 3 and 12 volts dc.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You mean two feet, right? 24"?
    How much water do you need to move, and what kind of batteries were you thinking of powering it with?
    Even small sealed lead-acid batteries would quickly "run out of juice" if they were asked to empty a 55 gallon drum to a tank higher up via a pump.
  5. DHEN
    Dec 7, 2009
    9
    I would like to use a 9v batt. the pump will run no longer then 5 min. at a time, once or twice per day. water flow can be minimal
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Minimal, like a couple of drops?
    A 9v "transistor" battery won't last long at all driving a motor.
  7. Duane P Wetick
    Apr 23, 2009
    408
    19
    Everything is dependent upon the amount of water (litres/min.) you want to move and how high (head) you want to lift it. Gravity is working against you when lifting water. Even a small (25 litres/ min.) boat bilge pump takes ~ 3 amperes @ 12 VDC., so consider the application and voltage source carefully when making a selection.
    Cheers, DPW [ Spent years making heaters out of op-amps.]
