Simple audio switch help
Discussion in 'General Electronics Chat' started by MarkMyWords, Oct 1, 2008.
  1. MarkMyWords
    Oct 1, 2008
    I'm trying to design a simple audio switch that can take two different stereo inputs via a standard common-ground 3.5mm jack and output to a single 3.5mm headphone socket with, say, a single-pole-double-throw switch to select between the two inputs.
    I have started looking at using two transistor loops that are mutually exclusive based upon the action of the double-throw switch, however, I am a bit out of my depth when it comes to wiring up the stereo signal and also not distoring the sound.
    If anyone has tried this before or knows a good online example, I would be very greatful.
    Thanks. Mark
    ```````````````` ______
    Input 1 -----------|??????|_______ Output
    Input 2 -----------|_____|
  2. MarkMyWords
    Oct 1, 2008
    Update: I've given up on the elaborate transistors and gone with a SPDT relay :)
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is the simplest solution.
  4. Externet
    Nov 29, 2005
    780
    58
    Hi.
    Use a CD4053 integrated circuit.
    Miguel
