simple audio (sine wave) oscillator
Discussion in 'The Projects Forum' started by ThyratronTube125, Mar 13, 2012.
  1. ThyratronTube125
    Feb 7, 2012
    Can someone provide an easy sine wave (audio) oscillator that doesn't need too many parts? (i.e. phase shift oscillator)
    Also, can a Colpitts/Armstrong/Clapp circuit be used to generate audio tones? (Those above mentioned are usually used with RF circuits).
  2. wayneh
    Sep 9, 2010
    12,405
    3,255
    Use the FreqGen app on your iPod. It'll give you sine, square or triangle waves over the full audio spectrum.
    Probably not what you were looking for, but you haven't explained why that wouldn't work.
  3. Obi_Kwiet
    Apr 4, 2011
    7
    Are you looking for an IC?
  4. t06afre
    May 11, 2009
    5,939
    1,222
  5. DickCappels
    Aug 21, 2008
    2,782
    675
  6. crutschow
    Mar 14, 2008
    13,521
    3,388
    You could use an XR2206 function generator chip. It will generate sine, triangle, and square-waves. The sine-wave does have a small amount of distortion so it's not suitable for high quality audio distortion measurements, if that's what you need.
  7. ishaan3731
    Member
    Jun 23, 2011
    43
  8. Veracohr
    Jan 3, 2011
    559
    77
    If you just need a single frequency, try a Wien bridge oscillator:
    \frac {Rf}{Rg} = 3<br />
f= \frac 1{2 \pi RC}
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    The circuit you posted is extremely simple. It has nothing to control its output level. Its output will rise until the opamp is badly clipping with lots of distortion.
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    Exar XR-2206. I built a benchtop signal generator using it.
