simple audio amplifier for loud "beep beep'' sound.
Discussion in 'The Projects Forum' started by steven2410, Jul 7, 2014.
  1. steven2410
    Jul 7, 2014
    16
    Hi everybody, I'm new to electronics and hoping to build a simple circuit that can generate a loud "beep beep"or "ticking bomb" sound ( or anything like that) - the sound would be on/off for 0.3s interval. I have found sth on instructable for this, however, the sound is not loud enough (Used 10W speaker). I need a very loud sound that can be hear clearly from ~20 m away and powered by battery cell ( those 9V or 1.5V cells). I have a 10W & 8 ohm speaker at home.
    It would be lovely if anyone can give me the circuit for this. Any directions, instructions or advises are appreciated.
    THis is the ticking bomb circuit i mentioned above: http://www.instructables.com/id/Ticking-bomb-package/
  2. shteii01
    Feb 19, 2010
    3,507
    512
    Assuming ideal performance.
    10 Watts=8 Ohm*I^2
    I=1.12 Amperes
    That is not a joking amount of current.
    This came out of the Mouser search: http://www.mouser.com/ds/2/405/slos527a-88277.pdf
    If you setup two 9 volt batteries in series, this will give you 18 volts. I don't know how long the batteries will last, but it meets the required 10-30 volt supply needed for above linked audio amplifier IC.
  3. shteii01
    Feb 19, 2010
    3,507
    512
  4. Lestraveled
    May 19, 2014
    1,957
    1,218
    Here is your circuit with an amplifier strapped on. It uses two 9 volt batteries.
    Mark
  5. steven2410
    Jul 7, 2014
    16
    i'm new to electronics and have no clue on integrate this amplifier into the circuit. It would be gold if you can give me a working circuit.
  6. Lestraveled
    May 19, 2014
    1,957
    1,218
    This is your circuit with the added amplifier. It is complete. It is simply drawn a little different.
  7. steven2410
    Jul 7, 2014
    16
    i have tried your circuit on solderless board, but it doesn't work ... i'm pretty sure i get the circuit on the board right
  8. Lestraveled
    May 19, 2014
    1,957
    1,218
    Oops
    I took you original circuit an added an amplifier. I checked the data sheet and pin 7 should be connected to pin 6.
  9. steven2410
    Jul 7, 2014
    16
    It works now, but the ticking sound is not much improved ... Thank you for your circuit. Guess i will try to look into piezo buzzer circuit.
