Simple Assembler Question
Discussion in 'Homework Help' started by TwoPlusTwo, Nov 29, 2010.
  1. TwoPlusTwo
    Oct 14, 2010
    51
    I'm trying to learn Assembler programming and I'm supposed to write a program that does this:
    - stores 5 numbers
    - reads those numbers and calculates the sum
    - writes the sum on the diodes of my practice board (STK500)
    Here's what I got:
    .nolist
    .include "m32def.inc"
    .list
    .def sum=R21
    clr sum
    out ddrb, sum
    ldi R16, 0x2c
    ldi R17, 0x0f
    ldi R18, 0x49
    ldi R19, 0x37
    ldi R20, 0x19
    add sum, R16
    add sum, R17
    add sum, R18
    add sum, R19
    add sum, R20
    out PortB, sum
    But nothing happens. Do I need some sort of ending to the program?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You have not set your PORTB direction as outputs. You set them to inputs. Fix this and you should get your LEDs to light. I am assuming that you put current limiting resistors in series with your LEDs.
    You will also need to put what is commonly referred to as an "infinite loop" at the end of your program or it will go out into the weeds.
    hgmjr
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings twoplustwo,
    I have moved your thread on the AVR code assistance request over to the homework section. Let me know if this is not a class assignment and I will be happy to move it back to the programming forum.
    By putting the post in the homework section the intent is to signal to our members that help is to be provided contingent on the your effort. You have provided the requisite first attempt and encountered your first snag. I have provided a couple of comments in the form of suggestions without being specific on how to accomplish these suggestions. The idea is to lead you to the answer rather than blurt out the answer. By leading you to the answer in gradual steps you will have the opportunity to dig for the answer. It is important that we take this approach since you will not be able to consult AAC in the middle of a test so you can develop the skills needed to work out the answer on your own in an examination environment.
    Let us know if you still have questions. We encourage you to seek out the solution on your own as much as possible so that the knowledge will be yours rather than being spoon-fed to you.
    Good Luck,
    hgmjr
  4. TwoPlusTwo
    Oct 14, 2010
    51
    Thanks for the tip! So here's what I have now. Am I getting closer?
    .nolist
    .list
    .def sum=R21
    ldi sum, 0xff
    out ddrb, sum
    clr sum
    ldi R16, 0x2c
    ldi R17, 0x0f
    ldi R18, 0x49
    ldi R19, 0x37
    ldi R20, 0x19
    add sum, R16
    add sum, R17
    add sum, R18
    add sum, R19
    add sum, R20
    loop:
    out PortB, sum
    rjmp loop
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    That looks much better. Did it work in your breadboard?
    By the way, You don't need to place the out PortB, sum inside the loop.
    hgmjr
  6. TwoPlusTwo
    Oct 14, 2010
    51
    Ok, thanks. I'll try programming the board tomorrow.
