Simple analog DC diagram
Discussion in 'General Electronics Chat' started by Joneken, Jul 30, 2016.
  1. Joneken
    Jul 30, 2016
    5
    Hi, I need to have a simple DC diagram to act as a warning, when a connection is on, a light or buzzer to be off, and when same connection goes off, that light or buzzer activates.
    This is for a hobby and therefore can't gone complicated
  2. AlbertHall
    Jun 4, 2014
    2,278
    450
    You will need to be more specific about 'a connection is on'. Connection of what to what?
  3. Ramussons
    May 3, 2013
    562
    92
    Do you want it using "active" components like a Transistor or "passive" ones like a Relay?
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Or just a switch, batty and buzzer?
    shteii01 likes this.
  5. Joneken
    Jul 30, 2016
    5
    My connection is conducted between two galvanised nails, that are inside a moisture medium, as a normal situation, with an acceptable level of moisture the buzzer supposed to be off, when the moisture reduced and connection between to heads of nails gone off, I need the buzzer goes on. ( please note the medium is not soil, the buzzer could be, Piezo Electronic Buzzer Effect Tone Alarm 3-24VDC 12V Continuous Beep Arduino, therefore system should work with a 12V battery )
    Thanks and best regards
  6. Joneken
    Jul 30, 2016
    5
    No, idea, but the simpler the better.
  7. blocco a spirale
    Jun 18, 2008
    1,461
    370
    That's not what you said in your first post which suggested the input was a switch. Since no one knows what the "moisture medium" is or, more importantly, the resistance threshold at which the buzzer should sound, it's not possible to provide a solution. Perhaps you could find out that information?
  8. Alec_t
    Sep 17, 2013
    5,979
    1,138
    This may work for you, but success or otherwise would depend on soil/medium mineral content, nail spacing and immersion depth, in addition to moisture range.
  9. Joneken
    Jul 30, 2016
    5
    Hi, sorry I confused about your question, I think what I need is a 12 V battery of course plus a buzzer, I do not know how this communication is working, but I copy an explanation That I have send to another member.
    Hi again, sorry I was not clear, what I meant is that, there is a medium, like glass wool, that has a certain amount of water inside, therefore if these two nails with certain distance enter there, right amount of moisture will arrange needed conductivity between head of two nails.
    Hope it's clear the idea.
    Regards
  10. Alec_t
    Sep 17, 2013
    5,979
    1,138
    If the water is pure it is a very poor conductor, so the proposed method may not be reliable.
  11. hp1729
    Nov 23, 2015
    2,105
    235
    What is the typical resistance of the moist material? Clean water is not conductive.
    "Arduino" conflicts with "not complicated".
  12. Joneken
    Jul 30, 2016
    5
    Hi again, I do not have any idea, my meduim is stone wool and two nail with few millimeters distance inside of this stone wool, and whole concept is to keep this mediume with certain moisture and the distance of head of two nail could be adjust base on try and error and base on design of electric circuit.
    Best regards
  13. Alec_t
    Sep 17, 2013
    5,979
    1,138
    I suggest you do an initial experiment. Mount the 2 nails the required distance apart in the moist medium and tell us the measured resistance between the nails.
  14. shteii01
    Feb 19, 2010
    3,515
    515
    KISS, properly applied.
  15. AlbertHall
    Jun 4, 2014
    2,278
    450
    ...will always melt hearts.
  16. hp1729
    Nov 23, 2015
    2,105
    235
    Stone wool? As opposed to fiberglass wool? Are you working at 600 degrees and expecting to find moisture?
  17. AlbertHall
    Jun 4, 2014
    2,278
    450
    It is used for insulation:
    "ROCKWOOL stone wool insulation shields buildings and their occupants, improving safety, comfort and building value. The World Health Organisation has left stone mineral wool off its list of potential carcinogens following long-term studies. After more than 60 years in use, ROCKWOOL insulation has proven to be the safe and most durable choice."
  18. hp1729
    Nov 23, 2015
    2,105
    235
    I guess fiberglass wool was deemed unsafe? Last time I looked stone wool was a good insulator for higher temperatures.
