Hi all - I'm still at it (putting together my lab PSUs) & the doctor says the bandages should be off my hands in a week or two...
Question: Can a selectable current limiting switch be introduced to a variable voltage line to provide the user a set range for the current to load?
I've done multiple searches on this site, read lots of very complicated (to me, lol) stuff about BJTs w/ 317s, etc., as well as looked around the web. I just can't seem to find an explanation that's translates to something in my comprehension range (read that - "newbie dumbie").
Background: I have a very clean 12V supply to start with. I'm not sure of the current out. The PS was part of a very expensive RF rack panel from the 80s & it's still in great shape. As an example, the LCD meter in it is from Texmat & currently lists by itself for $79 - I got the whole unit for $15. The number of bourns variable resistors on the RF board alone make up the total cost, lol, but I digress.
Eventually I want to build a 30VDC supply to run the adjustable voltage sub-circuit, but for now, the 12 will do. The sub-circuit is the simple 317/337 design, widely referred to on this site & the web. I just would like to add a selectable range to the current (which won't be metered, just the volts are metered) so I can limit the current from <1.5A to down around 50mA (i.e., 1, 500, 250, 100, 50). That's to say, turn a knob, light an led at the selected current range.
I've seen a lot of items for limiting current w/ transistors, but just having a tough time finding one that uses resistors.
My brain is telling me this is way easy. I'm just not getting my mind around it for some reason. Anyway, thanks for the time.
