Simple 12 Volt Circuit Switch for Motorcycle
Status
Not open for further replies.
wozDaddy
Joined Feb 26, 2015
25
Hi all,
Project : Motorcycle headlight conversion to LED
Common H4 connectors used in mc headlights have 3 outputs. The center, 12 volts and the 2 outside negative (ground) from the hi/lo switch. The LED bulb is polarity sensitive. I need a simple circuit switch to change polarity to the bulb. I am thinking transistors, one for each output of the hi/lo switch. The max current needed to power the bulb is 80 watts. The bulb has 3 inputs. Center, negative and the 2 outside need to be switched positive separately. I have limited electrical experience and would rather ask than to do trial and error. My research identifies PNP and NPN type transistors ...... or maybe I need something else. (?)
Hope I explained this properly.
Thank you.
bertus
Joined Apr 5, 2008
22,278
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
There will be enough sites where automotive questions can be discussed :
Member selected automotive forums
Bertus
Status
