Simmultanous equations
Discussion in 'Math' started by jagjit Sehra, Mar 4, 2008.
  1. jagjit Sehra
    Feb 29, 2008
    25
    Hi Folks,
    Got a question regarding simmultanous equations. I am studying Electronics and have been looing at a certain type of response. The crtically damped response.
    vC = Aexp(mt) + Btexp(mt)
    where m is one value lets say -1. vC has intial
    value of 2.
    The problem is to obtain the values for A and B.
    The derivative of vC with respect time.
    dvC/dt = mAexp(mt) + Bexp(mt) + mBtexp(mt)
    (differentiated the second term using the product rule)
    assuming t = 0
    Putting values in.
    2 = Aemt + Btemt
    0 = mAemt + Bemt + mBtemt
    2 = A + 0 A must equal 2
    0 = -A + B + 0
    0 = -2 + B B must equal 2
    Therefore A and B both equal 2. Is that correct the way I have done it! It doesnt look right!
  2. Mark44
    Nov 26, 2007
    626
    It's not clear to me what you're doing. At the beginning you say assume that m = -1, but you don't use that value in your later work.
    After taking the derivative, it looks like you are setting d(VC)/dt to 0, but you don't mention that this is given information.
    Using all the information that you have, does A = B = 2 make sense? That is, do these values satisfy both the original equation and its derivative when t=0, and presumably for m=-1?
    Mark
  3. Mark44
    Nov 26, 2007
    626
    If you have these equations:
    V(t) = A*exp(-t) + B*t*exp(-t)
    V'(t) = -A*exp(-t) -B*t*exp(-t) + B*exp(-t)
    with these initial conditions:
    V(0) = 2, V'(0) = 0
    Then, yes, your work is correct; namely, that A = B = 2.
    I used your assumed value of m = 1.
    Mark
  4. jagjit Sehra
    Feb 29, 2008
    25
    Thanks Mark for confirming that. I must also apologise for bieng so vague with the description of the problem. I must say I have found this foroumn very usefull and hopefully one day day I can help somone aswell!
