Similar volt regulator to TL317
Discussion in 'General Electronics Chat' started by ranatungawk, Nov 6, 2009.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    Please tell me a Similar volt regulator to TL317, TL317cant be found easily
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have you looked at an LM317L regulator?
  3. ranatungawk
    Oct 30, 2008
    147
    Sorry i made a mistake....smiler to TL783....
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you explain what you wish to do with a TL783?
    Attaching a schematic will be very helpful.
    If you are considering building an adjustable power supply with a very wide range of output voltages, you will not likely be very happy with using a TL783 or an equivalent; as power dissipation in the regulator will get very high as the output voltage is lowered.
  5. peranders
    May 21, 2007
    87
    The TL783 is a high voltage LM317 and it can handle 125V! This makes it a bit special.
