silly cpu idea
Discussion in 'General Electronics Chat' started by ranch vermin, Jun 4, 2015.
  1. ranch vermin
    May 20, 2015
    85
    sorry... being dumb again.
  2. OBW0549
    Mar 2, 2015
    1,395
    941
    Ummm... fire?
  3. blocco a spirale
    Jun 18, 2008
    1,461
    370
    There's your problem.
  4. ErnieM
    Apr 24, 2011
    7,440
    1,627
    Nooo, sorry.
    It's being hit on the head lessons in here.
  5. joeyd999
    Jun 6, 2011
    2,757
    2,937
    Why does this thread make no sense to me?
  6. OBW0549
    Mar 2, 2015
    1,395
    941
    Because the original content of the top post has been deleted. Too bad you missed it: it was a real pie-thrower.
  7. MaxHeadRoom
    Jul 18, 2013
    10,853
    2,524
    Get Karnack :p
    Max.
    OBW0549 likes this.
  8. ranch vermin
    May 20, 2015
    85
    im sorry for being gutless and deleting my post... I am an idiot.
    but i think im actually correct here...
    a = (b+c) & !(d+e)
    I can do this with 2 resistors. But the catch is i give the output to discover the input.
    So I give a (a single), and then i get distribution of results, and makes sense to electricity.
    Seems crazy, but if thats the case, you can actually work all the logic backwards distribution to distribution, either way it doesnt matter. The input must be separated and only ever expand from a single result, but you are allowed to reuse the tracks and resistors (requires rebalancing) whats going to the other side, making it not the most infeesable thing ever.
    Ram is cycling the output to the input, and also a differential analyzer does the same thing, and i have to figure that out.
    I wont show the tracks, but I think im right now. a=b+c&!d+e is a really simple circuit, where you just watch the expansion from the - point (which has to be the output (a) and you have to give this side.) where the power is presented, then distributed amongst the other side, the electricity sucking from a single point to many destinations. (discovering the input, which seems useless, but it shouldnt matter in the end.)
    Transistorless logic.
    i hope you like writing your logic backwards!!!!
  9. OBW0549
    Mar 2, 2015
    1,395
    941
    In the original, you had a whole lotta batteries connected in series, some to (+) and some to (-), with (as best I could make out) an ENORMOUS bunch of jumper wires connected criss-cross/cattywumpus every which way for your "logic."
    Personally, I thought that was a much more elegant design...
  10. ranch vermin
    May 20, 2015
    85
    I actually know it works now.
    you can go distribution to distribution, it doesnt have any flaws.
    ok i have to go home cause everyone thinks im dumb.
  11. WBahn
    Mar 31, 2012
    18,088
    4,917
    This strike me as being pure babble.
    If you want to be taken serious, provide examples that can be reproduced by others.
  12. WBahn
    Mar 31, 2012
    18,088
    4,917
    I don't know that anyone THINKS anything of the kind. :D
  13. ranch vermin
    May 20, 2015
    85
    (white egyptian tech)
  14. djsfantasi
    Apr 11, 2010
    2,911
    880
    I think the answer is around 0:12
  15. WBahn
    Mar 31, 2012
    18,088
    4,917
    More babble.
    But, I must admit, that video does answer at least a couple of important questions.
  16. joeyd999
    Jun 6, 2011
    2,757
    2,937
    In fact, this thread now makes perfect sense.
  17. OBW0549
    Mar 2, 2015
    1,395
    941
    It's kinda disturbing that someone in that state is actually playing around with electricity...
  18. ranch vermin
    May 20, 2015
    85
    Well I think im right, I have to go proove it soon.
    If you want to make an old school arcade machine, you have to put the output back into the input. (probably with a few intermediatry object based building steps) And thats essentially what makes ram.
    And since crossing two wires(-) into a third(+) is an or, double the buss for inverse polarity, 1 bit of ram is pretty small this way, considering its just 2 nor gates feedbacking to each other.
    If you guys think im an idiot, oh well, i think i might not bother posting here anymore.
  19. joeyd999
    Jun 6, 2011
    2,757
    2,937
    Please don't stop. The entertainment is worth twice the price of admission!
    ErnieM likes this.
  20. WBahn
    Mar 31, 2012
    18,088
    4,917
    Promise?
