silicon wafer
Discussion in 'General Electronics Chat' started by vead, May 9, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    I want to understand how does silicon chip make from silicon sand,
    for my basic understanding I have done something
    step1- silicon raw material
    step2- silicon melted
    step3- silicon cooled
    step4- silicon wafer
    step5- silicon wafer clean by acid
    step6- polished
    step7- wafer cut into slice
    I don't know that's correct step and I know that's not enough for wafer preparation
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
  3. vead
    Nov 24, 2011
    621
    8
    step6- polished
    step8- n mos layer
    step9 - pmos layer
    step10-metalic layer
    you mean this type
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You forgot insulation layers(silicon dioxide). That is how they make the gate of a MOSFET.
  5. vead
    Nov 24, 2011
    621
    8
    so all step is correct
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Except for the number of times each step needs to be executed to make a functional chip. There may be other steps in some processes that I am not familiar with. Gimme a break, it has been over 40 years since I learned this stuff and I'm now retired. Did you read the article that I gave you the link for?
    vead likes this.
  7. GopherT
    Nov 23, 2012
    6,303
    4,026
    Raw silicon material is silicon, not silica sand (silicon dioxide).
    The silicon is purified over and over with a zone refining system.
    Then sliced into wafers
    Then polished and cleaned
    Then photomasked
    Expose photoresist
    Eliminate positive or negative resist space (depending on technology)
    Then fed into a vapor deposition (chemical or physical) - or ion beam.
    Then strip remaining photo resist
    Then return to * above (many times)
    Then cut array of chips on your wafer of silicon
    Then add leads
    Then test
    Then package (overmold) with connectors
    - I think I got most everything
    absf, vead and Papabravo like this.
  8. vead
    Nov 24, 2011
    621
    8
    you did not mention step where component fabricate on chip
    that's very hard part to understand
    we cut wafer into slice i think we will be fabricate component on this die then test and then package
  9. absf
    Dec 29, 2010
    1,493
    374
    Steps 8-10 should be before step #7. Making chips is like making PCBs. We would copy and paste as many copies as possible of one circuit pattern to fill up the whole blank PCB.
    After etching and cleaning and drilling on the PCB, we start cutting indivisual PCBs from the large PCB.
    Allen
  10. MrChips
    Oct 2, 2009
    12,624
    3,451
    You forgot the part where the silicon crystal is grown into an ingot.
  11. kubeek
    Sep 20, 2005
    4,687
    805
    absf and MrChips like this.
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    absf and vead like this.
  13. vead
    Nov 24, 2011
    621
    8
    look at this
    step 1- silicon ( raw material)
    step 2- silicon is purified
    step 3- silicon is melted
    step 4- crystal is grown into ingot
    step 5- then sliced into wafer
    step 6 then polished and cleaned
    I think we are ready to fabricate component on chip
    I want to fabricate transistor
    n mos layer
    p mos layer
    metal layer
    sio2 layer
    Q1- first which layer will be used on chip
  14. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Hypothetically or actually?:D
  15. vead
    Nov 24, 2011
    621
    8
    just Hypothetically,
    transistor
    n mos layer
    p mos layer
    metal layer
    sio2 layer
  16. vead
    Nov 24, 2011
    621
    8
    I have doubt you said , raw material is silicon , I think raw material is silica sand
    sand -> silicon gas - reactor -> poly-silicon -> electronic grade silicon -> cz method -> wafer
    sand is raw material from earth It convert into silicon gas , then silicon is purified in zone refining system and produced poly silicon
    please tell me I just want to confirm that I am right or wrong
  17. vead
    Nov 24, 2011
    621
    8
    does any one know the equipment that is used in vlsi technology
    chamber , quartz tube ,furnace
    which equipment used for oxidation , ion implantation and diffusion
