Silicon photodiode
Discussion in 'Homework Help' started by TsAmE, Jul 11, 2010.
  1. TsAmE
    Apr 19, 2010
    72
    I would like to know why is it that a current flows in the attached diagram, even though the diode is reverse biased (having a gap in the middle)?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It just so happens that the reverse current in the photodiode is light sensitive. For this reason, if the diode junction can be exposed to light, as in the case of the packaging of a photodiode, the light will affect the reverse current. You will notice that the magnitude of this reverse current is very very low.
    hgmjr
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. Ghar
    Mar 8, 2010
    655
    72
    There is always some current in a reverse biased diode (all kinds), usually on the order of microamps.
    The 'gap' in the middle of a diode, the depletion region, is always there to some extent so it must be able to conduct some current or the devices wouldn't work at all. Bipolar transistors require such a region to give you current gain where the base-collector junction must be reverse biased.
  5. TsAmE
    Apr 19, 2010
    72
    Oh I see. Dont diodes also steer current in a certain direction, so by making the photodiode reverse biased, does that mean that the current moves up? (even though this doesnt make sense to me as current always flows from + to -)
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
