silicon fabrication
Discussion in 'General Electronics Chat' started by vead, Apr 21, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    silicon is raw material . silicon is purified by acid then melted and cooled
    1)how does mos transistor fabricated on silicon chip
    which layers are used to design source, drain and gate?
    there are different type of layer like metal layer, poly layer that are used to design transistor
    2)how does vdc and ground make on silicon chip?
  2. tshuck
    Oct 18, 2012
    3,531
    675
  3. vead
    Nov 24, 2011
    621
    8
    MOSFET gate made of metal or poly silicon layer
  4. tshuck
    Oct 18, 2012
    3,531
    675
    The gate is a conductive material on top of an insulating material (typically listed as silicon dioxide).
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    if you want to fabricate silicon semiconductors, you need a lot of money and equipment. the layers are not glued together, they are usually difused into or onto the silicon.
  6. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    When I was young'un we made our own semiconductor by 'tickling' a chunk of germanium with a 'Cats Whisker' for a radio. :D
    Max.
  7. vead
    Nov 24, 2011
    621
    8
    I don't want to make silicon chip I am just trying to know how does transistor resistor, capacitor and Inductor fabricate on silicon chip with different layer
