Silicon diode resistance measurement
Discussion in 'Electronics Resources' started by marchen91979, Oct 1, 2010.
Thread Status:
Not open for further replies.
  1. marchen91979
    Sep 20, 2010
    Please, some one help answer the following silicon diode measurement:
    The reading on the test leads to the silicon diode 500 - 800 ohms, when reversing the test leads to the measurement, the reading is 50 - 80 ohms. What is the condition of this diode. Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What readings do you get when you measure a known good diode?
  3. inverter
    Oct 13, 2010
    If the test is meant to figure out whether the Diode is faulty or not, it seems to me that if this is measurement was done off circuit, then it looks like it is faulty.
  4. Bharatohri
    Nov 10, 2014
    When positive lead of the Meter
    Is connected with Anode of diode
    LED glows with negative lead of multimeter
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    the resistance of a siode depends on the meter. older meter types showed different readings than modern digital metrs. the digital meters should show the voltage of the junction when conducting, around .5 to .7 volts for silicon and .2 to .4 for germanium. thats in the foreward direction with the black lead on gthe cathode. reversed it should be nearly open circuit. thats for out of circuit only, in circuit, anything goes, there could be anything across the diode messing up the readings.
  6. joeyd999
    Jun 6, 2011
    2,756
    2,925
    Guys, this thread is four year old!
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    On average, it's actually less than two years old -- and getting younger with every new post! ;-P
    joeyd999 likes this.
  8. crutschow
    Mar 14, 2008
    13,493
    3,372
    It curious how new members seem to often engage in raising the dead in these forums.
  9. Lestraveled
    May 19, 2014
    1,957
    1,218
    Raising the dead.....it is that time of year.
  10. MrAl
    Distinguished Member
    Jun 17, 2014
    2,554
    515
    Yes that is strange isnt it. And the post that raises the dead often is unrelated to the main topic of the thread. This one was a little related i guess.
  11. alfacliff
    Dec 13, 2013
    2,449
    428
    I have seen on this board that when a person asks a question that has been asked before, he is refered to the origional post. if a person had the decency to search for his question, why not?
  12. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,515
    ...Especially that is was never originally satisfactorily answered, as touched on in post #5, you require a meter with a Diode Test range that is capable of passing a current through the diode, the resistance range on modern meters will not do it.
    Max.
  13. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
Thread Status:
