silica gel
Discussion in 'Electronics Resources' started by RRITESH KAKKAR, May 16, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I have seen silica gel in packets of LED many times, what is the technical application of it?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    RRITESH KAKKAR likes this.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    where where it can be used?
  4. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    You can buy 2lb bags of it from hardware stores used as a de-humidifier for rooms etc, one trade name is Dryit.
    Max.
  5. shortbus
    Sep 30, 2009
    4,092
    1,672
    Isn't the stuff for basements calcium chloride? Silica gel is commonly know as a desiccant and works best in a confined space.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    ICs are shipped to me from the supplier in sealed anti-static bags with huge packets of silica gel and a moisture indicator card. When I partially use the allotted supply, I reseal the bags with the silica gel still in the bag.
    High humidity is a top cause of component damage in storage.
    When silica gel has absorbed moisture from the air it no longer can serve its purpose as an effective desiccant. You can rejuvenate silica gel by putting it in a warm oven for a couple of hours.
  7. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    You could be right.
    Max.
