Signature for post
Discussion in 'Off-Topic' started by Pusle, Nov 3, 2011.
  1. Pusle
    Dec 23, 2009
    15
    How do you get a signature at the bottom of each post cuz?
    looked all through my profile and cant find
    it:eek::eek::eek::eek::eek:
  2. debjit625
    Apr 17, 2010
    790
    186
    Go to your Profile and then to "Customize Profile",From their, under "Control Panel" > "Settings & Options" tyou will find "Edit Signature".
    I see you have only 4 posts ,I don't know if you are allowed to add signatures or not ...anyway try it..
    Good luck
    Pusle likes this.
  3. Pusle
    Dec 23, 2009
    15
    Thanks bro, ill be a senior member soon i assume, i joined in 2009
  4. debjit625
    Apr 17, 2010
    790
    186
    You need more post count bro...may be 100 not sure,posting in Off-Topic will be not counted.
    Good Luck
    Pusle likes this.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I believe 10 posts is the magic number.
    This was done because people would ask a question in the homework section, get their help, then delete their posts and leave, never to returen. It is assumed this was to confound their classmates and professors.
    So the 10 post count level was added.
  6. JoeJester
    Apr 26, 2005
    3,387
    1,211
    There is a formula that increases the number of posts required for senior member status based on your font size wth respect to 12 points. It's (x-12)^x where x = font size. For fonts less that 10, it's (12-x)^x.
    Also embedded is the troll recommendation trigger, for fonts greater than 36 points. It shows up on Senior Members screens to remind them to ignore the trolls.
  7. Pusle
    Dec 23, 2009
    15
    Thanks for that joe, very helpful :)
  8. Pusle
    Dec 23, 2009
    15
    i got 10 and its not there still?
  9. praondevou
    Jul 9, 2011
    2,936
    489
    When I joined, as far as I remember 50 posts was the limit for "member" and 100 for "senior member"...
    Btw what's the point in having this title "whatever member"?? Doesn't make a difference.
  10. strantor
    Oct 3, 2010
    4,302
    1,989
    In the mean time, you could just cut & paste your signature into each post.
