signals and systems
Discussion in 'Homework Help' started by juhir, Jul 6, 2008.
  1. juhir
    Jul 6, 2008
    for each of the following signals determine whether this signals are periodic or not?If periodic find fundamental period.
    a. x(t)= cos2(2piet)
    b.x(t)= (-1)^n
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What have you come up with thus far in your own efforts?
    One way to solve these problems is to make a graph of the function. You will be able to tell whether they are periodic, and will be able to calculate any period easily.
    Another way to solve these problems is to compare the function to known periodic functions and look for similarities.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Simple intuition should illstrate that one signal is periodic, whereas the other is not. Btw, I think you have a misplaced "2" in question a).
    Dave
  4. juhir
    Jul 6, 2008
    can u solve it and give. Its for the first time i am studying the topic
  5. juhir
    Jul 6, 2008
    Can u solve it and give
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  7. roddefig
    Apr 29, 2008
    149
    You can prove that a signal is periodic if it repeats itself. The way to describe this concept mathematically is:
    <br />
x(t) = x(t+T)<br />
    Basically, x(t) is equal to itself T seconds later. You can generalize this as follows
    <br />
x(t) = x(t+nT) \ \forall\ n<br />
    x(t) is equal to itself every nT seconds, where n is any integer.
    If I remember my linear systems class correctly satisfying the first equation is enough to prove periodicity, but I would check with your notes to see what your professor wants.
