signal waveform
Discussion in 'General Electronics Chat' started by @hacker, Nov 30, 2014.
  1. @hacker
    Nov 30, 2014
    10
    While reading circuits i developed this doubt that why always the(input/output) signal wave forms are shown as in the form of pulse,triangular,sinewave but never in the form of a straight line (like DC current).Why so??
  2. crutschow
    Mar 14, 2008
    13,526
    3,393
    It's not "always" but most circuits are designed for AC since we are usually interested in processing signal information and, by definition, to carry information the signal must be AC.
    But there are some circuits, like DC coupled op amp circuits, that will respond to a DC signal level. An example use of such circuits would be in a DC power supply.
  3. @hacker
    Nov 30, 2014
    10
    Okay Crutschow,but on searching about this on web i found that mostly analog signals are represented in this type.So I want to ask u whether this has any relation with this above question?
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Many people would not regard a straight line as a 'wave form' ........ at least, not an interesting one ;).
  5. crutschow
    Mar 14, 2008
    13,526
    3,393
    I don't understand your question. :confused:
    I though that was answered in my post. Most analog signals are varying since most signals of interest vary.
  6. studiot
    Nov 9, 2007
    5,005
    515
    Can you think of (or have you come across) a circuit for which the input is a straight line?
    BTW I presume by a straight line you mean a constant, as opposed to a mathematical straight line, which is called a ramp function in electronics.
    Ramp functions are used in various circuits.
    The only type of constant function inputs I can think of would be resistive heating as in a torch circuit.
    The input to the bulb would (should) be a constant voltage / current.
    At AC the mains supply at the wall provides an example of a constant input, but it is so simple we don't normally bother to show it.
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    If you were plotting the response of a comparator circuit having a constant reference input and a varying input you might well plot the reference input as a straight line which the varying input plot crosses.
  8. MrChips
    Oct 2, 2009
    12,657
    3,461
    There is a misconception as to what constitutes a valid signal. Sometimes students examine a signal on an oscilloscope and then claim "there is nothing there".
    Nothing is still something. Nothing is information. A constant logic zero has as much information as a constant logic one.
    A voltage signal is a time series. It is a recording of voltages over time. If each and every recording is the same voltage this will be observed on an oscilloscope as a horizontal straight line. This is still valid and useful information, but as a previous poster said, not very interesting.
  9. studiot
    Nov 9, 2007
    5,005
    515
    Unless it's the inhibit signal to Dr Stangelove's bomb.
    t_n_k likes this.
