signal turn on led
Discussion in 'General Electronics Chat' started by guyromb, May 15, 2009.
  1. guyromb
    May 5, 2009
    28
    hello,
    I have a reciever that on his output i get 1khz sound (i can hear it using headphones) - I would like to turn on a simple led when this sound is heard. I also built a highpass\lowpass active filter.. I thought to use xor gate but not sure.
    Please help me:)
    thanks
  2. KMoffett
    Dec 19, 2007
    2,584
    234
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    You have made a filter that works.
    Afther this filter you can place a audio level meter.
    http://www.mitedu.freeserve.co.uk/Circuits/Audio/palm.htm
    On the place of the meter you can place a comparator.
    The comparator output will let the led trun on when the level is over the adjusted threshold.
    Greetings,
    Bertus
  4. guyromb
    May 5, 2009
    28
    thanks.
    I prefer bert's circuit (i have the components). The highpass\lowpass filter seems to work.. but the volume is low - should i amp. it again? (which resistors to use?) - i use lm324 (quad op.amp). This is the l\hpass circuit:
  5. guyromb
    May 5, 2009
    28
    Can the comparator be op.amp too ? but i am not sure about the voltages comparison (i get low voltage on the filter output)
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Are you using a single powersupply voltage?
    Then you can not connect the + input of the opamp to ground.
    You can make a "virtual" ground by using two equal resistors (say 10K) with a capacitor of 10 uF from the midpoint to ground.
    The top of the capacitor is your "virtual" ground.
    This you can connect to the + input of the opamp.
    Greetings,
    Bertus
  7. guyromb
    May 5, 2009
    28
    Thanks!! so just tell me if i understood correct:
    op.amp+ leg -> 10k resistor -> 10k resistor -> 10nf Capacitor -> ground.
  8. guyromb
    May 5, 2009
    28
    leg 11 ( op.amp gnd) and leg 4 (op.amp vcc) can be conntected as normal to the +\- right?
  9. guyromb
    May 5, 2009
    28
    Now i hear the sound clear and strong !!!!!!!!!!!!!! :D
  10. guyromb
    May 5, 2009
    28
    Can you explain me about the "virtual ground" please?
  11. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    I have drawn in your schematic what I mean.
    Greetings,
    Bertus
  12. guyromb
    May 5, 2009
    28
    bert .. i tried your circuit but i hear the 1khz very low again... Moreover, when I transmit the sound or not - i get the almost same output voltage.
    However, by chance i got the sound very high (also i see on the voltmeter that there is a change in the output voltage).
    What i did:
    leg 3 (op.amp +) to 10kohm to 10kohm to 10microfarad to ground.... but not sure if it's good :D
  13. Audioguru
    Dec 20, 2007
    9,411
    896
    Pin3 should be at half the supply voltage. Maybe your input source is grounding the voltage at pin3.
    Make the circuit like this and look in Google for Multiple-feedback Bandpass filter.
  14. guyromb
    May 5, 2009
    28
    Is that bandpass filter circuit for 1khz pass? I forgot to mention that use ~5-6v power
  15. guyromb
    May 5, 2009
    28
    It's just killing me that i have done everything and it works.. and just the simple thing - turning on a led - doesnt work :(
  16. guyromb
    May 5, 2009
    28
    Please, somebody can help me?
    I can hear the 1khz using headphones on the reciever output... I just need to convert this sound signal to '1' logic only when this it's heard.... I tried many things and I really don't know what to do :(:(
  17. guyromb
    May 5, 2009
    28
  18. Audioguru
    Dec 20, 2007
    9,411
    896
    The filter should feed a level-detector circuit. It turns on the LED.
  19. guyromb
    May 5, 2009
    28
    I would expected that i would see a voltage differents - when i transmit or not
  20. guyromb
    May 5, 2009
    28
    so what do you recommend me to do?
