Signal transmission and filtering
Discussion in 'Homework Help' started by cheypr, Dec 14, 2010.
  1. cheypr
    Thread Starter Active Member
    Oct 13, 2009
    34
    Hello guys, I need help to nail this question?:cool:
    9. Describe a method using square waves to evaluate the fidelity of an audio amplifier. Assume the amplifier has a linear phase response. Would triangle waves be better?
  2. JoeJester
    Apr 26, 2005
    3,403
    1,230
    No it would not be better.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    A measure of the fidelity of the amplifier would be the amount of distortion of the square wave. Usually there will be some "rounding" of its corners and inclination of the vertical edges on a lo-fi system. In other words, high frequencies will be cut off.
