Hey all,
So I am having a bit of trouble with some inputs on a board I am working on. It is a DDS setup. (http://www.analog.com/en/rfif-components/direct-digital-synthesis-dds/ad9910/products/product.html if anyone cares) The board is controlled via USB using labVIEW to work switching on 4 of the input pins on each board. The setup we have works fine except for issue -- on our longer cabled inputs, sometimes one of the input signals comes in about 5-10 ns late than the others -- during which time the DDS board will not accept changes in a bit, and rather ignore them. For the record, this is not a data line, it simply controls what register is accessed on the board, so it won't switch quickly. I need to set up a board to accept incoming signals, delay 10-15 ns, during which it picks up and holds all of the other signals, then dumps them afterwards.
The thing that I am unsure of is how to set something up that will send a 1 when a state changes, which can be reset at the end of a delay period.
Any ideas? This may be fairly obvious, I haven't done too much circuit design.
Thanks in advance,
JD
Thanks in advance,
JD
