signal sampling and recovery
Discussion in 'Homework Help' started by jut, Nov 16, 2009.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    The signal x(t) = cos (14*pi*t) is sampled at a sampling interval of T = 0.1 seconds. Can we recover the signal from its samples (why or why not).
    I attached my attempt at a solution.
    What I did was this: I did a fourier transform on the signal, X(w), which resulted in two delta functions: one located at -14pi, the other at 14pi. Now, the fourier transform of the sampled signal, Xs(w) equals X(w) plus X(w) shifted by integer multiples of n*2*pi/Ts which equals 20*pi.
    From my plot of Xs(w), there are delta functions interspersed to the left and right of the original X(w). I don't know if the original signal can be recovered with an anti-aliasing filter.
      File size:
      50 KB
      13
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Lotta work -- and completely unnecessary.
    Code ( (Unknown Language)):
    1.
    2. 2πf = 14π
    3. f=7 Hz.
    4. fs(minimum) = 14 Hz.
    5. 1/14 = 71.4 milliseconds
    6.
    The sampling frequency must be twice the highest frequency component. A sampling frequency of 10 Hz., corresponding to a sampling period of 100 milliseconds, just won't make it.
  3. jut
    Aug 25, 2007
    224
    that's a whole lot easier, ugh. :(
    thanks for the help.
