On the resistor R2 one gets positive-edge triggered signalOriginally posted by skypher@Apr 16 2006, 07:46 PM
Hi there,
the circuit below is from "The Art Of Electronics" and does the job of a
differentiator along with a signal rectifier. What role does R2
play, apart from modifying the RC filter for positive voltages?
[post=16224]Quoted post[/post]
Could someone please expain how this circuit works in a bit more detail ?Originally posted by dragan733@Apr 16 2006, 04:20 PM
On the resistor R3 one gets negative-edge triggered signal
[post=16227]Quoted post[/post]
Originally posted by dragan733+Apr 16 2006, 11:20 PM--><div class='quotetop'>QUOTE(dragan733 @ Apr 16 2006, 11:20 PM)</div><div class='quotemain'>On the resistor R2 one gets positive-edge triggered signal
[post=16227]Quoted post[/post][/b]
Just having a guess here seeing they don't tell you what it is there for. Probably just the load resistor.Originally posted by skypher@Apr 18 2006, 04:25 AM
But I thought R3 forms a voltage divider with the diode, to compensate for the forward drop of the rectifier diode...?
Sure, but it does not say anything about the additional resistor, it just explains the subcircuit that provides diode forward drop voltage compensation.
[post=16249]Quoted post[/post]
R1-C is a differentiator (in fact a high-pass filter with ~1,6 MHz) along with a signal rectifier D2 to get only the positive voltages. The R3-D1 circuit with the additional +5V supply is just for compensating the forward drop voltage of D2.Originally posted by Mazaag@Apr 17 2006, 02:24 AM
thanks guys
[post=16235]Quoted post[/post]
So basically we are compensating for the 0.7v loss across the D1 ? but how are we doing that with this circuit? I can't really see that.. are we adding an offset so to speak of 0.7v to the output ?Originally posted by skypher@Apr 18 2006, 04:28 AM
[post=16282]Quoted post[/post]
R3 and D1 form a voltage divider. The voltage drop at R3 is 5V minus D1's voltage drop, which is very close to D2's (provided they are the same type). So the voltage drop that gets lost at D2 gets added.Originally posted by Mazaag@Apr 18 2006, 06:28 PM
[post=16289]Quoted post[/post]
skypher,Originally posted by skypher@Apr 18 2006, 12:27 PM
[post=16290]Quoted post[/post]
Weren't you trying to find out what R2 was for?Originally posted by skypher@Apr 19 2006, 04:27 AM
Yes, and I still do, but that doesn't keep me from explaining the other parts of the circuit, which I do understandOriginally posted by windoze killa@Apr 19 2006, 12:45 AM
[post=16296]Quoted post[/post]
Please keep on asking until you understand it all!Originally posted by Mazaag@Apr 18 2006, 08:26 PM
(sorry pleaes excuse my noobinism).
If R3 and D1 were replaced by ground, all current from the 5V supply would be shorted to ground and no voltage whatsoever would be dropped across R1.I understand that R3 and D1 form a voltage divider. So wouldn't the potential across R1 would be LESS by 0.7 ? I mean, if you were to consider the circuit without R3 and D1 ( say its ground )
Try to look at R1 and D2 as a second voltage divider in line with the first (formed by R3 and D1).I'm kinda confused... I still dont' see how that divider circuits "adds" 0.7v to compensate for D2 forward votlage drop of 0.7v....
I don't think so. It's not consistent with the style of the book found elsewhere. Load resistors are usually dashed or marked specially otherwise.Originally posted by windoze killa@Apr 18 2006, 02:03 AM
[post=16266]Quoted post[/post]
The applicable section from Horowitz & Hills Art of Electronics, Chapter 1, Foundations, Section 1.30 Titled, Circuit applications of diodes, subsection Signal Rectifier, on page 48 and 49.the circuit below is from "The Art Of Electronics" and does the job of a
skypher thanks for you help...however I still don't get it !Originally posted by skypher@Apr 19 2006, 12:54 PM
Both work the same way.
[post=16328]Quoted post[/post]
Why would I want that?Originally posted by JoeJester@Apr 20 2006, 03:51 AM
R2 provided a different differentiated time for positive pulses compared to R1 on the negative pulses,
Yes.Originally posted by Mazaag@Apr 20 2006, 04:39 AM
first question, does that mean the AC signal superimposed will be offset by 0.7v downwards?
Yes to all this.so we want to compensate for this 0.7 voltage drop by D2. So somehow , we need to ADD 0.7v to the output of the filter.. such that when we run the AC signal, it will start off 0.7 higher than it should be , drop by 0.7v because of D2 , and everything is fine... right ?
okay , so we need to add 0.7 volts to the node between the Capacitor and R1.. correct ?
so we have a circuit ( 5 volts with R3 and D1... ) this is a voltage divider, with 0.7v across the diode , and 4.3 across R3... so far so good ?
Easy. Forget the capacitor and its input, we can do without them for explaining this. A voltage divider, formed by D2 and R1, remains. 0.7V has to fall off at the diode, so R1 does not do much to the voltage.second question.. how do I analyze from this point, to show that the voltage at the node between the capacitor and R1 has increased by 0.7v......
So because the voltages at the nodes between R1 are the same, "no current" flows and therefore we can consider the resistor shorted ? and therefore we get an addition of 0.7 ?Originally posted by skypher@Apr 20 2006, 07:13 AM
Yes.
Yes to all this.
[post=16357]Quoted post[/post]
