signal in series with base bias volt.
Discussion in 'General Electronics Chat' started by hobbyist, Dec 16, 2008.
  1. hobbyist
    Thread Starter Distinguished Member
    Aug 10, 2008
    774
    65
    When we analyze a simple one transistor amp, we solve for the thevinin equivalents.
    Then we put the signal source in series with the thevinin volt. and res.
    So we can use superposition to analyze the signal effect on the amp.
    Where the signal adds to the bias volt. and subtracts from the bias volt.
    However in actuality we hook up the signal source in parrallel with the bias voltage on the base term.
    So how did they come up with putting it in series for correct analysis of the amp?
  2. mik3
    Feb 4, 2008
    4,846
    63
    They are not actually in parallel because you couple the bias voltage and the source voltage with a capacitor. In this way only AC passes through the capacitor which is added on the DC bias voltage.
  3. KL7AJ
    Nov 4, 2008
    2,047
    295
    Back when transformer coupled audio amps were a lot more common, you'd often see the bias voltage applied through the secondary of a coupling tranformer. In this case the bias voltage and the signal voltage were indeed, in series.
    Don't see that configgeration much these days, though. ")
  4. steveb
    Jul 3, 2008
    2,433
    469
    Another way to look at is to consider that the AC source is a more "ideal" voltage source than the DC bias voltage. In other words, the DC bias voltage is going through a relatively large source impedance and can be pulled away from its average value by the AC source with low source impedance.
    If you were to put an ideal AC source in parallel (with capacitive coupling) with an ideal DC voltage source (with zero source impedance), then it wouldn't work. The AC signal would be zero since it is shorted to ground through the DC source.
  5. hobbyist
    Aug 10, 2008
    774
    65
    Yeh, elenco electronics AM/FM 14 trans. radio kit uses that configuration in there IF stages. The sec. is part of the base bias, on the next stage.
  6. hobbyist
    Aug 10, 2008
    774
    65
    So it's safe to say that even though the signal is coupled through cap. in parrallel with the base bias volt. due to the sources not being ideal, then the sources have the effect as if they were in series for analysis purposes.
    Thanks everyone.
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    Another approach to this is to use Kirchoff's Current Law. The input signal through the coupling capacitor is just another current source into the node.
    Eric
