signal help
Xufyan
Joined Aug 3, 2010
114
1. The problem statement, all variables and given/known data
Solvinf the unit time step equation mathematically.
2. Relevant equations
x(t) = u(t+1) - 2u(t) + u(t-1)
3. The attempt at a solution
How can i solve this signal mathemtically :( and using plotted signals , i couldn't understand,
here is my approach and i'm not sure it is correct,
i simply wrote the coordiantes of each signal,
u(t+1) = (-1,1)
-2ut = (0,-2)
u(t-1) = (1,1)
and then added them which give answer = '0' :(
is this the way of solving the signals ?
please help
mik3
Joined Feb 4, 2008
4,843
Give values to t, 0 1 2 3 and so on.
At each value evaluate each term in the equation. If t in u(t) is equal or greater than zero then u(t) equals 1.
Remember the definition of a step signal.
Xufyan
Joined Aug 3, 2010
114
i wanna solve it without putting a value for t,
what my teacher did is , he simply draw those three signals and cancelled out the opposite signals , the remaining signal is the answer ! what the hell was that ???
is that a way of solving a signal ?
he said there is no mathematical approach to solve signals (btw we have just started signals n system and this was my 2nd lecture),
i wonder how the hell there is no way to solve the above equation mathematically.
there must be a way which my teacher doesn't aware about,
can you draw the output waveform of this signal and approach of solving it without assigning a value of t ?
mik3
Joined Feb 4, 2008
4,843
Yes, you can plot each u() component of x(t) individually and then sum them up.
Assume the component u(t+1):
set t+1=0 and solve for t
t=-1
Thus, at t=-1 the signal rises from 0 t 1 (step)
Do the same for all u() components.
Xufyan
Joined Aug 3, 2010
114
i already did that as i mentioned in my first post , re-read the first post please.
but how to solve further,
after this step ??
look at this,
u(t+1) = (-1,1)
-2ut = (0,-2)
u(t-1) = (1,1)
you said exactly what i've already posted.
can i solve it like
(-1,1) + (0,-2) + (1,1) = 0
is this correct ? if not then how to solve it ?
mik3
Joined Feb 4, 2008
4,843
after this step ??
look at this,
u(t+1) = (-1,1)
-2ut = (0,-2)
u(t-1) = (1,1)
can i solve it like
Draw the three signals on the same sheet and sum them up.
t_n_k
Joined Mar 6, 2009
5,455
after this step ??
look at this,
u(t+1) = (-1,1)
-2ut = (0,-2)
u(t-1) = (1,1)
can i solve it like
The three functions are not continuous over the region from t=-∞ to t=+∞ and cannot be summed as you propose.
Your summation only holds true for either t<-1 or t>=1.
