Signal ground and DC ground
Discussion in 'The Projects Forum' started by francoisC, Jun 29, 2010.
  1. francoisC
    Jun 29, 2010
    I currently have a video camera that has the following pinout:
    Power (24VDC)
    GND
    Signal
    It takes 24VDC as input and outputs a video signal. Shouldn't there be a separate Signal GND as a reference? Or is it acceptable to use the DC GND as my Signal GND reference?
  2. John P
    Oct 14, 2008
    1,638
    225
    Obviously, it's what they're doing. To them, there's only one Gnd. Hopefully, their internal circuit does use separate grounds and joins them at the incoming connector. If I had to work with this device, I'd wire my system the same way, but in reverse--a dual system with 24V Gnd and signal Gnd, connected only at the outgoing connector.
  3. francoisC
    Jun 29, 2010
    I'm using 24V GND and Signal GND as the same throughout my entire system, and when I input the RCA jack into a monitor, I'm getting horizontal lines the slowly move upward in my video...
    Any clue what could be causing this? Would isolating them and only connecting them at the outgoing connector make a difference?
    EDIT: http://www.deepsea.com/pdf/specs/Multi-SeaCamManual010810.pdf
    That's the camera being used.
  4. flat5
    Nov 13, 2008
    403
    17
    Put a 'scope on the 24v and ground and see if it has signal on it. It should be very clean.
    Is it an old camera? Check for slightly bad solder connections on the print. Maybe a bad ground connection. You might have a cap failing.
  5. francoisC
    Jun 29, 2010
    When I plug my camera directly into my system (using DC Ground as the same as Signal Ground), it works fine.
    However, when I connect the camera to a ~600 ft long umbilical then into my system, I'm getting the "hum" in the video signal...
    Any ideas to offset perhaps the umbilical?
    edit - the video signal in the umbilical is through coax cable with the shield connected to the "GND" pin.
  6. flat5
    Nov 13, 2008
    403
    17
    I would try a three wire cable. If hum is still there, I would try to connect the shield at one end only.
    Can you run one end on battery power and see what happens?
