signal generator
Discussion in 'General Electronics Chat' started by, Apr 16, 2014.
    Apr 16, 2014
    I have a question I need to use a signal generator to generate a sin wave at a frequency of 10hz to 50 khz. Also I need tge output voltage to be a constant voltage of 30 vac and the voltage can't change based on sweeping tge frequency. I beleive I can accomplish this with a variac signal generator and amplifier. My question is if I do a sweep on the signal generator tge voltage should not change correct. If I had 30vac it should stay at 30
  2. w2aew
    Jan 3, 2012
    It will depend on the quality of the generator and on the load. For example, if the load impedance changes over that frequency range, then this can also affect the amplitude.
