Signal from a Coin Slot Acceptor
Discussion in 'Programmer's Corner' started by Moonstar78, Jul 11, 2011.
  1. Moonstar78
    Jul 7, 2011
    39
    Hi everyone!
    I have a SR-1210 coin slot acceptor.
    input and output pins configuration:
    2-gray both ends for counter
    1-red for +12VDC supply
    1-white for coin signal
    1-black for ground.
    i want this thing to connect in may pc and create a timer program in .net/java application. Does anyone can help me with this problem?
    I really need this stuff to work in my net cafe. Thank you in advance for those who can contribute/share their skills in this matter.
  2. John P
    Oct 14, 2008
    1,638
    225
    I think you'll need a processor (Arduino or PIC) and suitable serial interface.
  3. Moonstar78
    Jul 7, 2011
    39
    Thanks for the advise! but how can i get this processor that you are telling to me? Do i need a software to detect my coin selector?
    What would i do next?
    the link below is the model that i am using for now.
    http://www.gzyinasi.com/pview/?43.html
    Please give me more info so that i know what would i do next.
    Thank U! :)
  4. guitarguy12387
    Apr 10, 2008
    359
    12
    Here's a quick way to start:
    http://www.adafruit.com/products/68
    You will probably went to spend quite some time experimenting with this before you try communicating with a computer. On second thought, there is code out there written for arduino that communicates with the computer using lots of different protocols. If you have a decent background in programming, you could probably pull it off by simply copy-pasting this code into your chip.
    Go experiment!
