Signal expression manipulation
PsySc0rpi0n
Joined Mar 4, 2014
1,762
Hi guys!
I need help on manipulating a signal expression that I can't go through it. I have the result but I'm struggling hard to get there!
The original expression is this:
\displaystyle {S_{AM}\left ( t \right )=4\cdot \cos \left ( 2\cdot \pi \cdot 720\cdot 10^{3}\cdot t \right )+\cos \left ( 2\cdot \pi \cdot 710\cdot 10^{3}\cdot t \right )+\cos \left ( 2\cdot \pi \cdot 730\cdot 10^{3}\cdot t \right )}
The final result I'm trying to achieve is this:
\displaystyle {S_{AM}\left ( t \right )=4\cdot \left ( 1+0.5\cdot \cos \left ( 2\cdot \pi \cdot 10^{4}\cdot t \right ) \right )\cdot \cos \left ( 2\cdot \pi \cdot 72\cdot 10^{4}\cdot t\right )}
I already identified that the carrier is the term with 720 kHz with amplitude of 4 and that the other 2 terms are something like 720 + 10 and 720 - 10 and that the 10 is a common term but I can't move on!
Any help is appreciated!
WBahn
Joined Mar 31, 2012
30,057
Try working it backwards starting from the final result and using trig identities to express it as the sum of sinusoids.
