Signal divider
Discussion in 'General Electronics Chat' started by millard, Aug 9, 2005.
  1. millard
    Aug 9, 2005
    Electrics is not my strong point I'm more of a mechanic, I need to take an electrical signal which is counted and make 2 pulses appear as 1.
    If you are wondering what I'm doing: I'm trying to use a motorcycle rev counter on a car engine as it is considerably more compact but as I'm using a V8 it fires twice as many times as the 4 cylinder engine it was designed for.
    I guess its a very simple circuit, all and any help greatly appreciated.
  2. Ron H
    Apr 14, 2005
    The devil is in the details. If you had logic-level pulses available, all you would need is a toggle flip-flop, which divides frequency by two. The hard part is getting from whatever your input is, to a logic level pulse. This is going to be difficult without a hands-on look at what you have.
  3. millard
    Aug 9, 2005
    All I know is that a 12v pulse comes from the distributer to trigger the coil to fire a 50000v charge back to the distributer, that is then sent to each spark plug in turn.
    what is a "logic level pulse"?
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    A logic level pulse is in the ballpark of three to five volts when high and les than half a volt when low.
    If you you can tap off the 12v coil i/p and use a voltage divider to bring the sampled pulse down to this level, then you might be able to divide frequency with the flip/flop and then amplify flip/flop o/p for the tachometer to use.
    You will need to know about voltage dividers, also flip/flops, simple amplifiers, and possibly de-bouncing.
    voltage dividers
    Flip/flop used to divide frequency by two
    Table of Contents for Amplifiers Chapter
