signal diode
Discussion in 'Homework Help' started by chrisbry, Jun 5, 2011.
  1. chrisbry
    Jun 4, 2011
    I need help finding Vx, Vy, Vxy, and Ixy for the following circuit.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    364
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    A simplistic approach is to replace the diode with a battery of value equal to a typical diode forward voltage drop of (say) 0.7 Volt. Remember the diode can only conduct in one direction, so as long as the diode can be forward biased in this circuit configuration, then the equivalent circuit can be analyzed to give the values you require. As KJ6EAD suggests this is then simple DC circuit analysis.
    In reality a diode is a non-linear device so the exact solution to the problem is more complex, but this is probably not the intent of the question.
