Hello
The title of this thread is misleading , but I kept getting server errors so I had to change it.
Signal current using a DMM
I was trying to measure the current going out of a constant current driver with my DMM the other day ( feeding an led).
When I connected the TTL to +5volts (I'm powering the whole thing with 5V)
then I got a current of say 50ma , then without doing any adjustments I connected the TTL to the micro which was outputting a few tens of Khz square wave and the DMM showed more than twice the amount of current , about 120ma.
I understand that the DMM current mode is not designed to measure signal currents so this is an error right? When I give the TTL say.. a 50khz square wave then driver should output half the average current than if I connected the TTL to 5volts right?
Just want to make sure there isn't some trickery going on ...
Thanks in advance for the answers
