signal converter
Discussion in 'General Electronics Chat' started by Ramasule, Nov 6, 2004.
  1. Ramasule
    Nov 6, 2004
    12
    Greetings, my problem is this.
    I am interfacing a plc with a vfd. The problem I am having is that the vfd signal out is a 4-20ma loop and the plc card takes a 0-5 volt signal.
    What could I use to convert a 4-20ma signal to a 0-5 volt one.
    (I was thinking of a Fet and a battery and having the 4-20 control the voltage through put through the fet.)
    Any suggestions welcome
    Thank you,
    Derek
  2. Iodem_Asakura
    Sep 14, 2004
    140
    I think it easier and better for you to use an optocoupler.
  3. Ramasule
    Nov 6, 2004
    12
    optocoupler hmm that sounds interesting, anything that i could use that you would find in basic electronics kit.
    (also scematic if you can include one pls thanks)
  4. Iodem_Asakura
    Sep 14, 2004
    140
    Well, here is a transistor optocoupler. Read it to see if it works for you.
    If the on current is higher than 20 mA, you must build an amplifier so it amplifies the 20 mA to a level that can make the optocoupler to turn on, but that amplifies the 4 mA to a level below that, so the optocoupler remain turned off.
    By the way, sorry for been late :p , i have been a little busy.
  5. Ramasule
    Nov 6, 2004
    12
    No problem, can u check the file again though im reading it as corrupted.
    Thanks.
  6. Iodem_Asakura
    Sep 14, 2004
    140
    Try to download it again, 'cause i downloaded it from my post again, and it is ok.
  7. Ramasule
    Nov 6, 2004
    12
    Must be my security settings.
  8. Iodem_Asakura
    Sep 14, 2004
    140
    Ok, tell me your mail, and i'll send you the file. :)
  9. dimas_lilik
    Nov 10, 2008
    can you email scematic for to convert a 4-20ma signal to a 0-5 volt one
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'll make one in a bit. Basically an op amp current to voltage convertor along with a summer to set the 0 point.
    Here is the starting point.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, this will do it, you can use variables potentiometers to replace the odd resistances.
    Since most op amps do not go rail to rail you will need supply voltages that exceed your output range, as well as a plus and minus power supply.
    Have you really looked at the dates of the original posts? You really should have started a new thread, those guys are long gone.
