Signal conversion
Discussion in 'General Electronics Chat' started by mikefr24, Nov 4, 2007.
  1. mikefr24
    Nov 4, 2007
    My brother installed a 8 cylinder engine into a car that used to have a 4 cylinder. Now of course the tachometer is reading 2x the correct RPM. The original car tach reads pulses from the distributor and he would like to use the original tach with is new engine. Is there a way to do this with logic chips or a analog circuit to divide the signal by 2?
    Thanks,
    Mike
  2. recca02
    Apr 2, 2007
    1,211
    if it uses a counter u would need a flipflop that will divide the pulses applied to its clock input by 2.
    (edit: maybe someone can provide a more elegant solution)
  3. John Luciani
    Apr 3, 2007
    477
    A single chip sounds like an elegant solution to me ;)
    (* jcl *)
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I concur. Any old flip-flop chip capable of running on 12V and sourcing enough current for the meter circuit would work just fine.
  5. chesart1
    Jan 23, 2006
    269
    Should Mike be concerned about noise due to the steep rising and falling edges of the flip flop output?
  6. Nomad
    Oct 21, 2007
    43
    that shouldn't be a problem. i've not had any of my speed sensor or tach circuits cause a problem with a square wave output. i actually needed to isolate one project and used an audio transformer driven with the square wave, talk about a nasty output. but it worked fine.
  7. Dragon
    Sep 25, 2007
    42
    An innocent D-Flip Flop sould complete the puzzle without any glictches.:p
  8. recca02
    Apr 2, 2007
    1,211
    i was thinking of T or jk in toggle mode.
    what wud be the inputs for a D FF?
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You tie the ^Q output to the D input. The clock will toggle so the Q output changes at half the rate of the clock.
  10. recca02
    Apr 2, 2007
    1,211
    got it.
    thanks a lot.
  11. mikefr24
    Nov 4, 2007
    Thank you gentlemen. I happen to have a drawer full of Flip Flops. I will try one out and let you know how it worked.
    Thanks,
