Signal Conditioning circuit
Discussion in 'The Projects Forum' started by epcole, Aug 10, 2010.
  1. epcole
    Nov 18, 2009
    8
    I'm working with PVDF for pressure measurements for underwater blast pressure measurements. the problem I have is the rising slope at the beginning of the signal after the first shock. I have done this testing with a PCB transducer with signal conditioning device and it eliminates this issue. I have that slope when I use it without the signal conditioner. My question is that is there a circuit I can make possibly from op amps which will prevent this slope and keep my signal on a constant zero line?
    Thanks!
    Here is what the signal looks like right now
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Helo,
    Do you have a schematic?
    Are there capacitors in the signal path?
    (it looks like a capacitor problem).
    Bertus
