Thanks for replying Ron.
Although I would like less noise from my measurements, whats more important right now is to get the right values, at least within a reasonable error range. I'm fine with a few lbs fluctuation but I can't take a 20%+ error in my load readings. Thing is at high loads the fluctuations are ~1-2 lbs for a 100 lb load, but the actual values are way off. For example putting 55 lbs gives me a 42 lb readout.
I basically want to know are my calculations for what the load would be sound for a 2.0918 mV/V readout at 3,000 lbs? (my excitation voltage being 9.95V and ~480 gain). I literally have 2 days to figure this out, including today and that's why I want to skip the noise issue because the gigantic error in my readout is far more important. I will try to post my actual setup when I get a chance but if you could please comment on my approach to signal conditioning/amplifying my signal and getting a good readout (even with noise) that would be great.
Thanks in advance.
Thanks in advance.
