Signal Booster Circuit
Discussion in 'The Projects Forum' started by BBwolf, Apr 30, 2015.
  1. BBwolf
    Apr 30, 2015
    Hi guys, I'm fairly new to working with signals.
    So I am using 3 QP22B vibrating actuators (can be found here http://www.mide.com/pdfs/quickpack-actuator-sensor-datasheet.pdf ) and these are connected to an arduino microcontroller that sends a square wave so that the actuators vibrate. Since right now they are only working with the 5V signal from the microcontroller they are rather weak.
    Could anybody show me a circuit that I can use to amplify this voltage up? I would like anything from 50V to a 100V output if possible. Also I would prefer if the components used are on the cheap side or at least easily accessible as I assume I will need a set for each actuator.
    Thanks.
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    What is the drive frequency? If mains frequency, then a transformer plus a MCU-controlled switch would be the simplest/cheapest drive arrangement.
  3. BBwolf
    Apr 30, 2015
    The frequency can change but right now it's at 10Hz
