signal and system
Discussion in 'Homework Help' started by micro1, Apr 5, 2015.
  1. micro1
    Feb 22, 2015
    53
    hello every one
    signal and system
    properties of system Linearity
    I did my problem
    you can check my solution it is true?
      File size:
      100.1 KB
      42
  2. WBahn
    Mar 31, 2012
    18,065
    4,905
    I'm assuming that you mean
    y[n] = x²[n-1]
    If so, then this says that the present value of y is equal to the square of the previous value of x.
    This is NOT the same as
    y[n] = x²[n] - x²
    This says that the current value of y is equal to the square of the current value of x minus the square of something that is not even at a defined time.
  3. micro1
    Feb 22, 2015
    53
    if change the equation to
    X1 = X1 [ Xn - X ]
    X2 = X2 [ Xn -X ]
    X3 = X1 +X2 ==> ( X1 [ Xn - X ] + X2 [ Xn -X ] )
    X3 = X3 [ Xn -X ]
    X3 = X1 +X2 ( linearity)
    thank you for reply
  4. WBahn
    Mar 31, 2012
    18,065
    4,905
    So, if you had the continuous time signal
    y(t) = x²(t-1sec)
    are you saying that you would rewrite this as
    y(t) = x(x·t - x·1sec)
    Does that make ANY sense whatsoever?
  5. micro1
    Feb 22, 2015
    53
    ok, now is linearity and nonlinearity?:)
  6. djsfantasi
    Apr 11, 2010
    2,899
    870
    "I don't even know what I am talking about!" - Bud Abbott
    ...meaning I have the same doubts as WBahn
  7. WBahn
    Mar 31, 2012
    18,065
    4,905
    There is no point moving on to the distinction of linear and non-linear systems until you are clear on what a system is to begin with.
