Signal and system summing opamp math calculation support argument
majdi
Joined Jun 22, 2011
23
Hello and good day all, i need advice on this question. At least keyword or url so i can study more. For electronic calculation i successfully calculate gain, -vout and else. But this type i not really understand when input in x1(t), x2(t) the vout in y(t).
ericgibbs
Joined Jan 29, 2010
18,872
As its a Inverting Summing amp, its purpose is to add together the x1(t) and x2(t) signals together, and give the Sum as y(t),, the same as you would do adding two numbers,
Consider what effect the 'Inverting' within the amp will do to the polarity of y(t).
So your first, y(t)= x1(t) + x2(t) equation is correct, but include the inversion.
What are your answers to the questions to [v]. ?
E
majdi
Joined Jun 22, 2011
23
i). Time-varying or Time-invariant
y1(t-t0) -> corresponding to x2(t)
x2(t) -> x1(t-t0)
x2(t) -> coorresponding to y2(t)
y1(t-t0) = y2(t) Is not true. Which mean this is Time-Varying System.
ii). Linear or Nonlinear
-y(t) = x1(t)+x2(t)
The system is in linear system because the condition is in additive or superposition property.
iii). Instantaneous or Dynamic
The system is Dynamic System, this is because the output y(t) response at any instant t depend not only on the present value of input, but also on the past values of the input which is the value before t.
iv). Causal or Non-causal
This is Causal System because -y(t) = x1(t)+x2(t), which mean y(t) to the input does not depend on future values of that input, x1(t-t0) and x2(t-t0) but only on the x1(t) and x2(t) present and or past values of the input, x1(t-t0) and x2(t-t0).
v). Open-loop or Close-Loop
-Dont know much about this in signal and system view
ericgibbs
Joined Jan 29, 2010
18,872
There is negative feedback via Rf [10k] from the Output to the Input of the amp, so would you say its Open or Closed loop.?
E
majdi
Joined Jun 22, 2011
23
Close-Loop, since close loop perform operation with feedback. So this how signal and system related. Thank you ericgibbs
