Siglent SDG 1025 as RF generator
Discussion in 'General Electronics Chat' started by atferrari, Mar 5, 2013.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,672
    785
    For simple experiments in RF at around 10 MHz, I could have access to a SDG 1025 Siglent signal generator. Manual available here. I could be even buying it.
    What could be missing for it to serve as a proper RF generator?
    Somebody suggested to look at the capability to attenuate the output. I would dare to add, stability, but lacking previous experience I am not sure what to look at.
    No RF generator is available around here so this seem the sole option I have, if at all.
    Comments appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Reading the specs, the sample rate is 125Msa/s.
    At 10 Mhz, the signal will be created in 12.5 steps.
    I am affraid that the signal might contain quite some harmonics.
    If you could order in germany, you could take a look at thsi DDS genarator:
    http://www.box73.de/product_info.php?products_id=2266
    Bertus
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    According to the spec sheet the harmonic distortion at 10MHz sinewave output is -35dBc which corresponds to about 1.8% distortion. That would seem acceptable for most non-critical applications.
  4. atferrari
    Jan 6, 2004
    2,672
    785
    What about using the output for RF tests? It seems rather high.
    Could I go away with an attenuator? I fear to enter in new set of problems with that.
  5. crutschow
    Mar 14, 2008
    13,509
    3,385
    Do you mean is the distortion too high for RF tests? Unless they are very critical tests, I don't think so. RF distortion is usually not a big concern.
    An attenuator won't affect the distortion, but you may need one if you are testing the low level input of an RF amplifier.
  6. atferrari
    Jan 6, 2004
    2,672
    785
    I meant the output level. Isn't it excesive?
  7. crutschow
    Mar 14, 2008
    13,509
    3,385
    It is for low level RF amp testing. For that you may need to get down to microvolt levels which would require an attenuation of about 60dB. You can buy BNC fixed coax attenuators for this purpose.
