Do you have a datasheet for the transistor, or at least a manufacturer and part number?
This is a pretty new technology. Test parameters for the device should be given in the datasheet. However, with devices of that kind of speed, you'll be hard-pressed to find tools to measure it with at the high frequency end.
Well, it DOES contain a SPICE model they claim is valid up to 6GHz, along with what seems to be a reasonable schematic representation of the device and associated parasitics.
The S-parameters are going to depend upon the entire circuit, not just the transistor itself. When you're working in the GHz range, parasitics that would be insignificant at say, 100MHz become enormous. You really can't use standard multilayer ceramic caps, as their parasitic L and R becomes huge; so you'll need to use SLC's (single-layer capacitors). You'll have to account for the L and C of your PCB traces - but if you're operating in the GHz range, you should be using something like a ceramic substrate rather than something like FR4.
well thanx for your reply
But My question is after building the whole amplifier and lets say that the amplifier didnt work .. is there some way to test the transistor itself to make sure that the fault is either from the transistor itself or not?!
I dont think there is a way to fully ensure transistor operation at high frequencies, unless you actually build the amplifier or have special equipment. You can, of course, test the transistor for its characteristic curves in the low-frequency domain.
