After several weeks of problem grinding I have now arrived at the following point:
Byron Jeff's Trivial low-voltage parallel programmer, Linux Ubuntu 9.10 and Piklab installed using Synaptic.
After a problem getting the parallel port to do anything (please see earlier post), I now seem to be able to read the PIC.
If I try and write the same data back to the PIC to test the link, Piklab just shuts-down!
Does anyone else have this problem or knows what is causing this please???
