Shunt-Shunt Topology
Discussion in 'Homework Help' started by The_Cook, May 29, 2014.
  1. The_Cook
    May 29, 2014
    48
    Hi guys. Can anyone help me answer this question, I was looking at examples but I couldn't figure out how to answer the questions, or draw the A network, as the question circuit is really different from the examples I found online
    Would appreciate if someone helped me understand and do the problem:)
  2. crutschow
    Mar 14, 2008
    13,469
    3,356
    What is a "voltage-sampling shunt-mixing network"? :confused:
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
  4. The_Cook
    May 29, 2014
    48
    I looked it up and it's another way of saying Shunt-Shunt
  5. The_Cook
    May 29, 2014
    48
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    Page 59 on PDF, the slide number 56
      File size:
      102.7 KB
      34
  7. The_Cook
    May 29, 2014
    48
    Thanks, seems like it's mostly the same circuit just with different variables.
    Could you tell me which one is the β network, I have to circle it in the picture
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Which resistor is the feedback resistor ?
  9. The_Cook
    May 29, 2014
    48
    The feedback network I guess? Like it shows in the PDF that you linked me to
  10. daviddeakin
    Aug 6, 2009
    207
    27
    In the OP's question 'β' probably refers to the feedback fraction, because the universal feedback equation is often written:
    A(closed loop) = A/(1+Aβ)
    This should not be confused with the hfe or 'β' of a bipolar transistor.
    The feedback fraction is the amount of output voltage that is fed back to the input, so it is the gain of the potential divider formed by the feedback resistor and input resistor.
