Shunt motor
Discussion in 'Homework Help' started by bwd111, Aug 23, 2013.
  1. bwd111
    Jul 24, 2013
    117
    If a shunt motor running with a load has its shunt field open, how would this effect the speed of the motor? We know its not going to slow down or stop suddenly so can rule those out fast. Stuck between unaffected or speed up. Im really thinking speeding up would be correct. Im about 99% sure its going to speed up
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    It can speed up to destruction in some cases, this is why DC shunt motor drives have a field loss detection circuit to shut the motor down.
    This phenomenon also is seen on Series motors as a run-away condition because of field weakening as the rpm increases, and the reason they are operated with a load to restrict their maximum rpm.
    An automotive starter motor works on this principle, one reason why you should not run one on the bench unloaded.
    Max.
    bwd111 likes this.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    If the field developed a very high resistance, and thus very low current then I can agree that runaway and physical destruction would result. But if the field were opened completely then there would be no magnetic field for the armature to react against, and it is my prediction that the motor would coast to a stop and then catch fire. Or maybe catch fire before coming to a complete stop.
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Sorry that is not what happens in fact.
    Every generator and motor (usually) possesses residual magnetism.
    http://www.wisc-online.com/Objects/ViewObject.aspx?ID=IAU13808
    And is borne out by many past disasters.
    This is how a generator can come up to generation without any field voltage applied.
    And then provide field voltage from the generated voltage, (self excitation).
    Max.
    strantor likes this.
  5. strantor
    Oct 3, 2010
    4,302
    1,989
    Thanks for the correction Max.
