Shunt DC Machines (Rotational Losses)
Discussion in 'Homework Help' started by jegues, Dec 15, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    See figure attached.
    They give us details of the no load conditions for this shunt DC machine and I assume that's how you are supposed to find the rotational losses but I can't seem to figure it out.
    How do you obtain the rotational losses using the information provided from the no load conditions?
    Thanks again!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    At no load the motor presumably draws 5A at a set terminal voltage of 230 V.
    The shunt field would take 2A, so the armature has the remaining 3A. The armature resistance drop is 0.3V so the armature emf = 229.7V. The no-load power input is therefore found from the 3A current and 229.7V armature emf - which would correspond to the rotational loss.
  3. jegues
    Sep 13, 2010
    735
    43
    Thank you very much.
    It wasn't clear to me from the question that the no load condition was indeed at a terminal voltage of 230V.
