Should I use the ground?
Discussion in 'The Projects Forum' started by egoot247, Nov 22, 2011.
  1. egoot247
    Nov 22, 2011
    Hello.
    I have a wire, Wire ABC, with current going through it. When Wire DEF comes into contact with wire ABC, I want the current to no longer run through the BC part of Wire ABC. Could I possibly run wire DEF into some sort of "ground" so that the current through wire ABC runs through DEF into the ground, and doesn't continue its path along wire ABC?
    Does that work? Is my concept of ground not correct?
    I'm used to "ground" being the zero-point of nodal analysis, and in that sense, my idea makes no sense.
    What am I doing? should I just make the resistance of wire ABC very high and DEF very low?
    Here's a picture because I don't feel that I'm being very clear: [​IMG]
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    True dat!
    Current flows from high potential to low potential, along all paths available to it, such as resistors in parallel. Think of water flowing down a hill. If there's a difference in elevation (potential, or voltage), and a path (conductance), current will flow.
  3. CDRIVE
    Jul 1, 2008
    2,223
    99
    Ohms Law will apply here as in any circuit. IE, the current will divide between the low and high resistance paths as governed by this law.
  4. crutschow
    Mar 14, 2008
    13,472
    3,361
    Is the current AC or DC?
  5. T.Jackson
    Nov 22, 2011
    328
    14
    Where does it go?
    Electricity is the flow of electrons, while electronics is the control of them. We control them by wasting / burning them off. This is why almost everything electronic gets hot after it has been on for a while. I think that you could fry an egg on our Foxtel TV box sometimes.
    What you have shown is called "current branching'
  6. T.Jackson
    Nov 22, 2011
    328
    14
    When you switch the current ON, OFF, ON, OFF, ON fast enough -- the electrons radiate and leave the conductor.
    You have all of these invisible quataties of electrons floating around you as we speak.
  7. T.Jackson
    Nov 22, 2011
    328
    14
    Switch ON man.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If there is no resistance in wire ABC above where DEF connects, then you will have infinite current flow from the source to node 0. This is obviously an exception, and any proper SPICE program would abort with an error.
    So, if you wish to divert current from wire ABC, you will need a resistance both above the DEF connection point, and below the connection point.
    If there is no resistance between the connection point and ground/node 0 in wire ABC, then it is actually node 0, not ABC. In order for it to be considered a different node, you would need some kind of device between node 0 and the DEF connection point. Otherwise, when wire DEF was connected to wire ABC, they would all become the same node.
