No there is no need for one, The transistor and base resistor provide isolation between the 5V and the 12V.should I use an optocoupler here?
This is very interesting.I wouldn't.. Only time I use an optocouplers is if I'm going to be triggering a circuit from something far away like a sensor 50 or more feet from the circuit or in switching high voltage (AC line).
Other way around.. Usually have a 12 volt signal feeding the optoisolator from some distance. This isolates the electronics from the possibility of surges on the cable and adds a little noise immunity.This is very interesting.
Are you using the coupler to "drive" a long wire?
Can they "soup up" the output of a standard CMOS/TTL chip?
Ok, so it's not a "driver" but rather a pure "isolator".Other way around.. Usually have a 12 volt signal feeding the optoisolator from some distance. This isolates the electronics from the possibility of surges on the cable and adds a little noise immunity.
by Aaron Carman
by Jake Hertz
by Duane Benson
by Jeff Child
